Thanks, Gents.
This bad boy! Upgraded to springs from shock cord.
Switched off and set up as a dry run without the wood so I can be sure of the order of setting up.
Spray the instrument side with just enough water to soak the surface.
Prepare the kitchen foil.
Truss it up like the Christmas turkey, but neater.
Prepare the sandwich. One spring steel outer leaf and the heating blanket first, then the instrument side.
Followed by the second outer spring steel leaf.
Then the waist caul and the the spring clips for the ends holding the sandwich together.
Switch on and cook!
Up to temperature (140C) Wind the waist caul down and start bringing the upper and lower bout cauls around their curves.
Feel the resistance in the wood and as it gives, bring the sprung cauls down to the end of the sandwich.
Let the sandwich cool down and release the sprung cauls.
Then release the waist caul and slide the foil wrapped side out.
Remember me making this on the CNC machine earlier this year? Let the side cool, dry and relax in the eventual shape, even though there will be some spring back. The lamination method will remove most, if not all, spring back.
Rinse and repeat with the other instrument side and let is cool while clamped in the bender.
Lunchtime. Phew!
Switch on and cook!
Lunchtime. Phew!
