Mike's greenhouse and potting shed (finished)
Nice work, and to think it is just for a potting shed.
Should outlast your lifetime 8-)
It is good to see your daughter helping, especially painting. Thankless job.
Phil":24wosq8r said:
.....It is good to see your daughter helping......
:lol: :lol: That's my wife. She's older than me. I'm just going to go out and put a smile on her face but telling her what you said. :)
The glass arrives on Thursday, so the next update will be of the all-but-complete greenhouse. I just thought I'd give you a list of the prices I received for the glazing (supply only).
£961
£580
£365
£1953
They were all quoting for exactly the same thing. It just shows, you really do need to ask for a few prices.
£961
£580
£365
£1953
I found a similarly pretty wide spread on prices when I made my barrister bookcases. In the end it was cheapest by far to from Forsyth glass and get it delivered by their own transport from Glasgow all the way to Southampton provided I did not mind waiting a few weeks until they had enough orders for down south.
The dearest was a local firm but I had to collect from them.
Forsyth were the £961 price. The two cheapest prices were from local glaziers.
Hi Mike
This is looking very good indeed, I applaud your skills and attention to detail. I'm also building a lean-to greenhouse and I've just completed the dwarf stone wall.
Apart from the ironstone wall mine will be far more utilitarian and built from treated C24. I'm considering using Bedec Barn Paint Anthracite Satin as I've used it elsewhere in the garden and it is extremely good stuff.
What is the paint you (or rather your daughter :D ) used as the green mist coat and what Bedec top coat are you going to use?
Finally did you seal the ends of the sills before using the Hippo Pro 3?
thanks
Mike
Interesting questions, Mike. The other half of this building is a potting shed, and I painted that with Bedec Barn Paint. I tried to order Bedec Multi-Surface Paint in the same colour for the greenhouse, because it is the paint designed for planed timber. However, Bedec don't do MSP in that colour. I had a lengthy conversation with the technical people at Bedec, and they said I should use Barn Paint, which surprised me. The only thing they said was to make the mist coat slightly thinner, and to build up an extra coat. So, the inside of the building gets 1 mist coat and two top coats of Barn Paint (Dark Green). The outside gets 1 mist coat and 3 top coats, all except the cill, which gets 4 top coats.
I'm really please with how well it has worked. There have been no issues at all.
No, I didn't prime the mitres of the cills. The Hippo Pro 3 completely fills the joint, is flexible, waterproof, and paintable. I couldn't see any advantage in priming or sealing, because the Hippo stuff is sort-of doing the same job anyway. I growing to really like the stuff......much easier to use than silicon, and yet you can do a silicon-type bead at junctions. It's really handy that it's paintable. And the big deal is how flexible it is when set.
Now come on.......let's see your photos! ;)
I think we'd left this at the completion of one door, so let's carry on from there.
Obviously, I made a second door, very much the same as the first. I then fitted them into the frame and chopped out for hinges:
Fitting allowed me to work out the size of the rebates in the meeting stiles:
I glued and pinned in some ply, and pinned in some bead (aaarrrgh.....mitres!) to hold it:
After offering the frame up into place, I discovered that its best position had it projecting from the face of the greenhouse frame. This was fine on the verticals, but meant I had a "shelf" at the top on which water could sit. So I planed up an off-cut to make a door head drip thingy:
That got a drip groove after that photo was taken.
Next, I grabbed my router. The one with a cable. It's been a while since it has seen any action. But I'd got 18 window hinge sockets to house out, and I'd got a jig I made for the same size hinges in the kitchen, so why not:
Actually fitting the windows into place was a bit awkward until I worked out this method:
The weather took me indoors for a while, so I made some staging out of 2x1 treated battens:
This detail is the one that has kept me awake at night. I hate back gutters, but there was an inevitability about having two of them once I opted for rooflights. It's absolutely essential to get a substantial fall side-to-side on a back gutter, becuase it is certain that leaves and bird droppings will accumulate there and potentially block them up. Here's what I came up with (it produced lots of shavings):
The leadwork had to be mainly done before the glazing was fitted, because access would be reduced to all-but-nil afterwards. I did the preparatory work at ground level:
Then popped them up into place. There were five pieces of lead this time, with one behind each rooflight, and separate pieces between:
The glass arrived:
A couple of pieces were broken:
I started the glazing by making up some lead strips and screwing them in place:
I puttied in the windows and the rooflights, slowly at first, but neater and quicker as I got into the job:
This is the stuff which was going to make the roof simple. Not just that, but if any panes ever broke, replacement will be straightforward:
https://www.expandingfoamtape.co.uk/collections/2-6mm/products/exp6102612
It is sticky on one side, and the foam is impregnated with some magic goo which makes it waterproof and watertight. It is about 2mm thick on the roll, but expands up to about 12 or 15mm thick if allowed (the less is expands, the more severe the conditions in which it remains watertight):
It only took an afternoon to glaze the entire roof:
Here is the glass with expanding foam tape above and below, and the cover strip:
Following the principle of always having an indoor and an outdoor job on the go, in case of bad weather, I had made a start on the cold-frame:
The windows had 6 joints, obviously. Every last one different! This is because the top and bottom rail were different thicknesses, as were the two stiles. I have 5 marking gauges, and they were all in use for this joint-fest. Here's just one:
I fitted the coldframe into place with some jollop and a few screws and plugs, then cobbled up a system for holding the lids open:
Fitting the ironmongery took most of a day. I didn't take a photo of my home-made rebate latch arrangement, but doing that and 9 window stays and latches, and fitting the rooflight automatic openers was a fair amount of work:
So barring glazing the coldframe and a final coat of paint, that's it, finished.
First class job. Sits in the landscape nicely.
I've made a note of that tape.
AJB Temple":28vjp4hb said:
......I've made a note of that tape.
It is often known by the brand name "Compriband", but that company doesn't sell to the public. Where it has been the difference between success and failure for me is in green oak framed conservatories, where I use it both for direct glazing to the frame, and for fitting windows frames to the framing. The frames can then twist and shrink as much as they like, and the glazing is safe from breaking.
Thanks Mike. I am sure I will track it down. Wish I had heard of it before.
Looks really fantastic Mike, though I won’t be showing it to my wife
Round here we call that tape compriband and is available in different thicknesses. It’s used a lot in green oak framing to take up the gap between the oak and other elements as the oak shrinks back to keep a weathertight seal. Such as where the oak abuts masonry or where the frame has direct glazing onto it. I can confirm it works a treat (I have built both scenarios into my house)
Regards
Edit looks like Mike types quicker than me
the bear":j1thbgkp said:
.......I won’t be showing it to my wife......
You're not the first forumite who has said something similar!
Excellent job Mike you should be very proud. I'm following quickly in your footsteps and the glass seal I have chosen is this https://www.screwfix.com/p/stormguard-d ... -25m/43490
What did you use to clamp over the roof panes as it looks like fence panel capping? It looks to be ideal. As a personal preference I'm not planning to use putty on the verticals but haven't settled on an alterative yet.
Mike
Those cover strips on the roof are just planed up bits of Douglas fir, same as the rest of the building.
If you don't use putty, you need beads or cover strips. There's a degree of buggeration whichever way you go.
brilliant Mike. and the veg plot looks large enough to feed an army.
:text-+1: for photos in a month of so time.
Thanks guys. I'll update in a few weeks with the place full of growth. It looks like the grape vine we wanted is unavailable anywhere in the country, so that will have to wait until the autumn.
Just realised that I cannot see any power in the greenhouse.
I haven’t either at the moment but I do miss my old set up of a small wooden cold frame with a soil warming cable that was great for bringing on seedlings at this time of year.
The cable is in the ground and poking up inside the potting shed, but it can't be connected until I have built the garage as that is where the cable starts. I started yesterday, so we should have power out there in the next few weeks. Obviously there is water laid on, and in due course I'll be doing guttering and a butts.
Love it mike, I've always wanted to have something similar on the end of my house.
Beautiful Mike. I think it looks so nice because of the tree next to it in blossom, giving the impression it has been there forever.
Thanks Wallace.
Thanks Nick. That's a greengage. I reckon it was probably struck by lighting, as it is split in half, rotten in the middle, and looking very precarious indeed. I fully expect it to come crashing down onto the greenhouse one day.
Looks amazing Mike, I daren’t show Mrs Woodstalker! Do you grow much veg? We did last year more than ever with my apocalyptic view of Covid plus we hatched the ducks too. This year I have made better raised veg beds and narrowed a load of manure from the stables up the lane down. Mrs W has an absolute ton of veg already at the seedling stage but we are hanging on before we plant due to the really late frost we get. Did a real dent in the sweetcorn last year.
I did try and persuade Mrs W to go for a polytunnel but she is not keen on the look of them.
We've got about 105 or 110 sq m of veggie beds, most of which have been in use for 3 or 4 years, and some for longer. Really lovely soil, with about 20 tons of horsemuck spread on them when we first prepared them, plus compost every year. We haven't bought a potato or onion for years.
Our biggest issue is vermin. We live entirely surrounded by a field, and when this is harvested the rats and mice are forced out into the surrounding woods, hedges....and our garden. They devastated the sweetcorn last year, and mice dig up the bean seeds every year. The biggest bonus of having a greenhouse is that plants can now grow in a vermin-free environment until they are safe to plant out
Looks fantastic Mike
I'm slowly taming the garden at our place. It was extremely overgrown and full of tree roots. I've been slowly clearing areas for vegetables etc. Weeds are a big problem so trying an area as no dig this year.
I was wondering if you could divulge where you got your douglas fir from - it looks like pretty good stuff. I've got some windows that have been replaced with UPVC that I'd like to put back to sash and case.
Jimmy
That looks excellent, already like it has always belonged there. Top job Mike !
Around here there are so many red kites now I can't imagine the rodents stand much chance !
We've a few kites. Lots of buzzards. We rely on kestels to thin out the populations of rodents.
It's great having all of Mike's photos and detailed notes, but I feel a bit disappointed that there hasn't been a TV crew recording the whole story of his house and grounds - it would have been a lot more interesting than ordinary TV property shows.
They could even have injected a bit of the artificial jeopardy that seems compulsory nowadays.
"Will Mike finish his potting shed and still have time to make a pair of cold frames before teatime?"
Of course he will! :D
Another great thread Mike and all looking great with amazing attention to detail. Must be very rewarding when you stand back and observe the results of your endeavours! Well done. I’m looking forward to the garage build.
Thanks!
I'm in deepest Kent tomorrow, as it happens.....
