I think we'd left it about here:
It got a quick slap of mist coat:
Then I starting setting out the roof:
At the top of the posts on the walls I had cut a vertical prior to erection, knowing that this would be almost impossible to do once it was fixed to the wall:
This enabled me to make the top joint for the gable rafters relatively easily:
As soon as I had the height and angles of the roof, I could do the plate supporting the top end of the rafters. At 5.5-ish metres long, it was too long to do in one piece, so time for a scarf:
Here it is just clamped at the ends, showing just how strong a decent wedged scarf is:
The wall needed finishing. A brick on edge capping course, with the mortar raked back out of the bed joint to facilitate the leadwork:
And a quick cold frame whilst I had the mortar mixed up:
Out of order, because I allowed a week for the mortar to harden up, but then the lead. I divided it up into 2m lengths, dressed it into shape, then fitted it, jammed in with the little clips in the 3rd photo:
I made all the rafters from 120x45 Douglas Fir (cut out from the big planks weeks ago). Here is the top end:
And the bottom, where it meets the wall plate (it's upside down here):
First dry fit, before they were all taken down for painting:
Right, now for some windows. There are 9 in all, plus the rooflights. So I cut 18 stiles and 18 rails to length:
I tried out various joints on some scrap. A double dovetail was just way too much work, and a mitre to the upstand behind the rebate took away a reference:
This is what I settled on:
Now, I know that windows aren't generally dovetailed, but I am not wanting to revisit this building in my lifetime, and with it being top hung those joints are going to be under a lot of strain. As I've said before, if I wasn't working on this I'd be working on something else, so it isn't an issue to take a little longer over something like this which I consider important.
Before starting on the joints, though, there were lots of rebates to cut on the router table:
This produced lots of great kindling:
Five arrises per 36 pieces of wood is more work than you'd imagine:
The actual production run of joint making was part hand-tool work, and partly on the bandsaw:
As the tails were cut individually, they each had to be offered up to the the rails so that each socket could be cut to fit, in much the same way you would making a drawer or a box except the pieces were too long to do across the bench, and had to be done along it instead:
I used a coarse (9 or 10 TPI) rip-filed tenon saw for the long-grain cuts:
I took this one to show my standard marking out format. If the two letters aren't both on the same face then I've got something wrong:
Dry fit, then glue up, then clean up:
Pinch sticks to check the diagonals:
More later. It's lunchtime!
