A bit more's been done on this, first and foremost the rebate for the back was machined this morning:
Second and foremost, what's been occupying me over the last few weeks is pondering about the drawer assembly and how it fits into the cabinet:
It looks on the face of it relatively straight forward, but if you'd care to try and work out how JK made it and then fitted it into the cabinet, you'll soon come to the conclusion, as I did, that it's 'ard! After the extinction of a few brain cells I've worked out a way of doing something similar which was glued up this morning:
...which is a dovetailed 'box'. If you look carefully at the pic, the pins are all the same size, but the tails gradually increase in width towards the middle. (The ones at the cabinet end are conventional) Cunning n'est pas?
I also decided to glue them with proper, '
old school' slow setting Araldite which takes
all the stress out of the process. It's messy, icky stuff so you need to get prepared:
...but the box has gone together without any difficulties and took approx just over an hour to get together. Had I used TB3 or even a 30min epoxy the glue would have gone off a long time before. The final, glued up drawer box assembly:
...is now residing in the airing cupboard to get the epoxy fully set by tomorrow morning. Note the excellent little Japanese sash cramp to pull up an errant gap on the shoulder - Rob
