Thanks. Very kind of you to say so.Beautiful. Quality work and a great WIP.
That's a very neat fix. I had a bit of difficulty of my own with the triangular infill piece.On the subject of mistakes, here's a close-up of the upper end of a back leg on my step chair. I hope most people will think there are decorative studs concealing the way that the top of the back is fitted onto the leg.
Experienced woodworkers will see that the studs are too far apart for that. The real reason is that the studs are plugging holes meant for dowels to hold a little triangular infill piece, down at the other end, marked C on Fig 1733 ...![]()
Now that's a cunning solution and proof that you have the required patience! It reminds me how that chair design threw up quite a few unexpected puzzles in the construction... I look forward to seeing if both your pairs of triangles come out the same size and fit together first time...That's a very neat fix. I had a bit of difficulty of my own with the triangular infill piece.
It is supposed to be dowelled to the adjacent pieces. I am not good with dowels but I set to work with a dowelling jig, making a pair of holes in a back leg and a pair of holes in Item C:
Although the pairs of holes did line up when fitted with dowels, the two parts did not. It was all going to turn into a terrible mess. I decided to go to mortice and tenon joints instead. I chopped out the area around the holes in the leg to turn it into a mortice instead and also made a mortice in the end of the sloping leg. Then I made a replacement Item C with the grain running at 90 degrees to that of the original (which I scrapped) and with tenons at each end.
Coming along really well.Here we have some dry assemblies to test that the parts will go together. Obviously, some overlength bits will need to be cut off. It was one of AndyT's valuable tips to leave the full size stubs at the lower ends of the front legs until a late stage. I still need to cut the housings to accept the steps and drill the upper rails for the screws for attaching the seat parts. The stick-on coloured spots to identify which parts go together was another of Andy's good ideas.
Ah - my apologies to Rob!Coming along really well.
But I must give credit for the coloured spots to Rob (Woodbloke). It works makes keeping track much easier, doesn't it?
Well spotted!. Yes, they are intentional. They should provide a bit of extra strength and keep the legs firmly in their intended position. I think they will also be helpful with my intended method of glue-up, as I hope to show.Quick question - looking at your picture, there are two bits at the bottom that I have circled.
They're not in the original design, which has those two triangles held together just by one of the steps, halfway up the legs where the full-sized square parts are. I don't think they could be a mistake, so are they a cunning modification?
I compared the designs of the two chairs and decided to adopt the lower rails from the Lisbon one.I assumed you were drawing from the Lisbon chair in your photo, which has rails there. It also avoids the little stubs of rail that have caused problems with their dowel joints. I think you do right to M&T them instead.
Well, I started preparing wood in early September and there is still a way to goI'm impressed by your pace. I've just looked back at my own one, to find that although I started it in February, it didn't get finished until nine months later, in November!![]()
Thanks. I made the scratch stock many years ago and never got round to making a fancy one. I think I kept on adding screws until I got a good grip on the bladeWell, this is all rather nice to watch. I've never had much luck with dowels either, and I like your alternative solution.
A couple of tools observations. My scratch stocks tend to end up looking like yours, with screws everywhere. It's really annoying when the blade slips out of position, and the only solution is to squeeze it even tighter. Your hand drill.....I've not seen an egg beater drill with such a large handle. Is it a normal size drill, or is it more like a breast drill? And whilst on the subject, I find the weakness of those drills to be the top (vertical) handle, which has to be fixed tight. If it rotates it takes the power away from the turning handle (poor description, but if you know what I'm talking about.......) Does everyone have this problem?
You can fit an extra side handle to some, so you can hold onto that with your other hand while you turn with your third armYes, I used a breast drill because the chucks of my "egg beater" style drills don't open up enough to hold a 3/8" bit. I have the same problem sometimes with the top handle coming loose. I suppose it could be fixed with a drop of Loctite on the threads.
Love the use of coloured dotsHere we have a trial dry assembly of the components of the back of the chair. There a lot of mortice & tenon joints in this job
Thanks. Yes it is very pleasant to work. I have just started to cut up the top of an old dressing table to make the seat and steps:Coming along very nicely.
That looks a lovely bit of salvaged mahogany - I presume it's really pleasant to work?
Thanks. I think the modification is very useful. The thread on the upright is 40 TPI, which make fine adjustment easy.That modification to the Stanley No. 271 looks rather splendid, as does the rest of this project.
Yes, milk bottle tops, melted in a soup can. I think they are HDPE. I got the idea from Pete Maddex.Is that a home made mallet from HDPE or PP, (bottle tops) ?
I reserve this 20 TPI saw for dovetails and delicate work:
I tried that and it worked well but my missus was not at all amused that I used the oven and stunk the house out for days.Yes, milk bottle tops, melted in a soup can. I think they are HDPE. I got the idea from Pete Maddex.
I can just about sharpen it with a very small file in the right light but it is quite a challengeHow on earth do you sharpen that? I'm starting to struggle with my 16 TPI saws. And setting them. Sheesh!
