Spectric
Often as a result of not fully cleaning the joint or moisture in the pipe. To clean 15 & 22 mm pipes externally and fittings internally buy yourself some of these, quick and easy .OK I have created leaks by poor soldering very ocasionally
Monument Copperkey 22mm Pipe & 22mm Fittings Brush - MON2922M
The reason plastic is now popular is simply you do not need the skill set, how many plumbers today can pull multiple bends on a single length of pipe to reduce the number of joints. Do they even teach pipe bending anymore in colledge, but there is really no excuse as if you don't want to lug a floor standing pipe bender around or find the portable hand bender hard work you can just buy a battery version that is great in confined spaces. The Rothenberger makes easy work of 22mm pipe, just not a cheap tool at around £1500 except when you think how much some woodworking tools like XL700 Domino and Lamello machines cost so comparative.
