Cabinetman
- Joined
- Oct 11, 2020
- Messages
- 5,784
- Reaction score
- 1,441
- Location
- Lincolnshire Wolds + Massachusetts
- Name
- Ian
Just a quick thought re-the handles, you could save weight and space by having leather tabs instead of handles/knobs?
Cabinetman":18scud4h said:Just a quick thought re-the handles, you could save weight and space by having leather tabs instead of handles/knobs?
AndyT":boeu86pf said:I am beginning to think this whole project is really an exercise in finding as many problems as possible and then solving them - and it looks a lot of fun!
There are so many other ways you could have made bottom drawer stops, that it must be quite frustrating for you having to choose just one![]()
Andyp":2vzavfhw said:I wise man (I think it was Bugbear) once told me if you can’t make it accurate make it adjustable. Very true for shooting boards. I think his design called for the fence to be bolted to the board with two bolts. One fixed bolt the other in an enlarged hole, enough to allow a little movement.
Andyp":1sue6f21 said:Will you be adding something nice and slidey for the plane to run along? Someone around here added a strip of formica.
AndyT":18lmp70v said:Re the little holes, my first thought would be to say leave them, it's a toolchest not a jewellery box. But I can feel your uncertainty - the standards elsewhere on this piece are so high - so I think something else is in order.
The simple option is to use whatever filler you have to hand. This could be epoxy or a mixture of sawdust and any glue. I'd probably use some Brummer Stopping but just because I have a tin and it lasts for years, generally setting like a rock long before it's used up.
The snag is that no filler will stay matching the colour of the surrounding wood.
If that bothers you, the most labour intensive option would be to cut back the holes with a chisel and insert little patches of the same wood, with the grain pattern matched and lined up.
I think they are a bit too big to rely on the finish to fill in.
AndyT":18lmp70v said:Hope your trip is ok and hasn't been affected by the floods - parts of Hong Kong had over 150mm of rain in just one hour the other day.
I gave one of those awayDr.Al":1ln8fofk said:I haven't had much time near a computer to carry on with the design work, but I did have a nice trip out to Wentwood Timber yesterday. I'd never been there before so wasn't sure what to expect, but I liked it a lot. I'd also been to Bristol Wood Recycling Project the day before (another first), but I'm less tempted to go back there unless I want construction timber (and can face the god-awful Bristol traffic again!). They sold hardwood, but Wentwood was much better value. I did come away from BWRP with some bits of birch plywood and a couple of lengths of unknownium though, including one that looks like maple to me.
Wentwood hardly had any poplar (one short piece, which I bought just to experiment with since it was only £7). They had loads of sweet chestnut though and, despite not having finished designing the box, I couldn't resist coming away with quite a lot of that. I've now got four long planks stored in the garage so I expect that I'll make the chest out of that.
I'm going away on holiday relatively soon and I'm going to have a go at making something or other (possibly just practice joinery) while I'm away. I obviously don't have a tool chest yet so I'll take my portable workbench. It also occurred to me that I have one of these in the shed:
I got this as a result of someone on another forum offering it free to a good home. I don't have a mitre saw any more as I sold it a year or two ago, but I kept hold of the stand just in case it came in handy.
It isn't especially robust, but the mounts for the mitre saw are a good size for holding my portable workbench and it fits behind the front seats in the car so won't be a problem to transport. I'll take it away with the workbench and see how I get on with that combination and it might help guide me in my design of the chest (and possibly a collapsible bench to go with it!) I wouldn't be surprised if I end up finding the mitre saw stand too flimsy as soon as I start chopping dovetails, but it won't hurt to have it with me.
Andyp":33zoqx8p said:I wise man (I think it was Bugbear) once told me if you can’t make it accurate make it adjustable.
That must be in the very dim n'distant past :lol: - RobLurker":27z9l6xh said:Andyp":27z9l6xh said:I wise man (I think it was Bugbear) once told me if you can’t make it accurate make it adjustable.
You might be right, but I thought I heard it from Rob (( wood bloke) originally.
AndyT":5sliu47r said:....But maybe the more realistic outcome is to recognise that you have uncovered a gap in the history of plane making, which will be your perfect excuse to embark on making planes for yourself? You've got the skills and the gear and I'm sure you could produce something to fit the bill.
AndyT":2ibpdnm1 said:Well, I can think of a suggestion...
Just to make sure I understand the problem - with your block plane, the difference in width between the iron base and the bulbous brass grip is almost nothing, unlike an ordinary Bailey style plane where the wooden handle is considerably narrower, and so clears the groove you want it to run in.
AndyT":2ibpdnm1 said:The ordinary way round this is to have a rebate, not a groove, and this works well for many of us, but I understand your wish to engineer an elegant solution. You like your constrained runway (which works well, so I have read, on the old Stanley 52 chute board/plane combo or its modern Veritas version).
AndyT":2ibpdnm1 said:I thought at first that a slimmer profile block plane would be the answer. Here's a photo of my 60½ (one of Stanley's low angle block planes, and my personal favourite) posed in front of a modern block plane that's like yours
The handle is lower, at about 52mm overall, but it has the same problem - it won't sit nicely in a 30mm groove of any useful depth.
AndyT":2ibpdnm1 said:So, I think you have cunningly designed yourself into a corner
AndyT":2ibpdnm1 said:with two nice solutions.
One is to find a plane of block plane size without the bulbous handle. The obvious choice would be a Stanley No 2 or No 1. They are about the size of a block plane but have an ordinary narrow handle. I don't have one to measure myself, but one of the wealthier forum members might oblige. Maybe one of your tool-hunting trips will provide one?![]()
Here's a recent example of a No2 that sold at auction in August - https://www.davidstanley.com/catalo...antique-and-modern-woodworking-tools-lot-782/. Don't forget to add 22% fees to the hammer price.
AndyT":2ibpdnm1 said:But maybe the more realistic outcome is to recognise that you have uncovered a gap in the history of plane making, which will be your perfect excuse to embark on making planes for yourself? You've got the skills and the gear and I'm sure you could produce something to fit the bill.
Mike G":2ibpdnm1 said:Absolutely fascinating, Dr Al. This is a really excellent thread, a lovely project, and full of ingenious high-quality work.
Mike G":2ibpdnm1 said:AndyT":2ibpdnm1 said:....But maybe the more realistic outcome is to recognise that you have uncovered a gap in the history of plane making, which will be your perfect excuse to embark on making planes for yourself? You've got the skills and the gear and I'm sure you could produce something to fit the bill.
Take that as an order rather than a suggestion :lol:
AndyT":18zjz0wu said:Well, that sounds very positive!
And thanks for the link - I'd not seen that one. And a single iron is all you need for end grain where the shavings have no strength. There is so much good info online about planemaking now, from the last ten years, since YouTube and the hand tool revival became mainstream. But will you go for wood or metal? How could you possibly find out which would be more suitable for your needs???
Andyp":3ozy2tmo said:Going back to the block plane dilemma.
Why be so precious about modifying your own tools to fit your purpose? From my, all be it limited, experience craftsman have been doing that for years. Unless it would be too uncomfortable for use outside of the shooting board i cannot see the problem in reshaping to suit your needs.
Andyp":3ap974hz said:Going back to the block plane dilemma.
AndyT":3ap974hz said:But Al needs an excuse to try plane making!
AndyT":3ap974hz said:(Otherwise he could just knock up an alternative narrow lever cap for his block plane that wouldn't foul the side of the groove. It could also have a sideways handle on it.
AndyT":3ap974hz said:I only mention this because I'm sure he's already thought of it but doesn't want to disobey orders.)
